plugs keep fouling..help!!!
its a 08 l76 with 317 heads.
btr springs retainers and valve seals
tick turbo cam
br7ef plugs at stock gap .24
speed density tune, no maf, no o2's
i have breathers on the 2 rear valve cover ports. and the valley cover port running into the tb.
compression test was held for 2-3 seconds per cylinder
took pics of all the exhaust ports. all look similar except for #7
i can take any pics you need to further help. i appreciate all feedback
thanks!
Often misunderstood and poorly design engine evac system can red flag in similar fashion.
A hotter plug will help
Also who is tuning your engine a revision by a qualify second opinion may proof helpful, not an invitation to start a war among tuners but rather to eliminate possible human error before it gets to a more expensive path.
Ignition system spark intensity test.
Check all your grounds clean all contacts and make sure all wires are in top shape, make sure you have enough grounds, locate/check ECM ground wire.
