Piston/Bore Clearance
How close can I get with feeler gauges? I AM gonna buy a 4-5 mic before assembling, just asking. I set each piston in it's bore with the crown flush to the deck and stuck the feeler in at least an inch while loading it to the opposite side. I get 0.002" perpendicular and 0.020" parallel to the crank. I know the pistons are barrel-shaped, but do these numbers sound right? These are forged Wiseco 4.070" slugs...
Did you have a shop hone the block for those pistons and now you're just trying to double check their work?
Where are you measuring? If the cylinder was honed with a torque plate, you may see a variation when you measure without a torque plate. It almost certainly won't be as straight and round as it was with it.
The shop may have meticulously honed the bores to the nominal bore size, and the pistons do usually gain a thou from the coating so that seems normal. Most of the shops I use will add between .0005" and .001" to the nominal bore size just to give a bit of safety clearance.
Even cast or hyper **** can use just a smidge of extra size as well....
Thanks!
