Oil to top of motor, LS3
This is a head/cam 2012 ls3 car with stock oil pump.
Just remember the rockers never ones go around full circle as the rock travel at the shaft only sees about a 3/8 inch.
Lots of things where made different in the LS engine family as compared to the earlier small blocks, still I am convinced the LS engine gets too much oil at the rockers and use a 0.030 oil restrictor in the push rod.
A 0.030 diameter continuous hot oil supply pressurized 30 psi or greater is still a substantial amount of oil for the sole purpose of lubricating only the rocker arm.
