Help with my 6.0 power curve
Old Sep 22, 2015 | 11:24 AM
Rick1991's Avatar
Default Help with my 6.0 power curve
I got my truck dyno tuned and have been happy with the power for awhile now but wondering what my next mods should be to the motor so my power curve will increase. I called TSP and they said their cams power curve should be 1900 - 6300/6400. My power curve is like 2600 - 5800 right now. Mods are...
- Stock shortblock LY6 (VVT delete)
- Stock L92 heads with LS3 headgaskets
- TSP cam kit 229/236 112LSA .624/.615
- 7.40 Pushrods
- LS3 intake manifold, injectors
- Factory LY6 TB
- Big 4 inch piping intake with massive filter
- 1 3/4" Mid length headers to a y, then into a single in and dual out magnaflow
- T56 Trans
Dyno graph
Old Sep 23, 2015 | 09:41 AM
slogo's Avatar
- 7.40 Pushrods
- Factory LY6 TB
- T56 Trans
Dyno graph
Well I wouldn't call tsp if that is what cam you have and that is what they told you, I would call a
Well known cam grinder and tell
them exactly what you want. Google might help out. Good luck
Old Sep 23, 2015 | 09:52 AM
Know It All's Avatar
Put a blower on there....that'll help!
Old Sep 23, 2015 | 10:52 AM
lemons12's Avatar
Its because TSP doesn't have a -clue- what they are doing.
I had a 370" with a stock ls3 top end and a TSP cam (got it CHEAP from a buddy).
It sounded great. That is about where the pros stop.
It ran like complete dog ****.
Was lazy as all get out down low and died off quick up top.
They are a joke.
Call John Bewley and have him spec you a cam. Viola, problem solved.
Old Sep 23, 2015 | 11:14 AM
redtan's Avatar
Why do you say your current power curve starts at 2600?
Only way to get more power everywhere would be with some better heads.
Old Sep 23, 2015 | 11:15 AM
redtan's Avatar
They are a joke.
That's call you putting in a cheap mismatched cam in there expecting great results.
Old Sep 23, 2015 | 11:16 AM
Rick1991's Avatar
This is interesting, I always thought tsp was pretty knowledgeable. The cam is a tsp cam, I may call Lil Johns then and ask. I also want to be set up for a turbo in the future, so I would probably go with a slight turbo cam. Would a holley hi-ram and nick Williams tb benefit me?
Old Sep 23, 2015 | 11:19 AM
Rick1991's Avatar
That's where it looks like it starts on my dyno sheet, and it does feel like turbo lag almost with this cam. Motor doesn't start waking up until later rpms.
Old Sep 23, 2015 | 11:23 AM
redtan's Avatar
That's just where the dyno operator started the pull, has nothing to do with where the "power curve" of the cam is. He could've started that pull at 1000rpm or 4000rpm.
I go back to the heads. I would say your issue with being laggy is mostly the big heads on a small bore rather than the cam. Plus low compression would make for a car that's lazy to drive downlow.
Get some ported cathedrals with 11+ compression and watch that car with the same cam feel like an animal down low.
Old Sep 23, 2015 | 11:32 AM
Rick1991's Avatar
Ya it still is a dog down low, my 3.42 gears don't help it. My heads are rectangle now so would going cathedrals help much more then rectangles? Also whos site is good to check for these heads?
Could I just port, Polish and Mill my current ones?
Old Sep 23, 2015 | 11:44 AM
redtan's Avatar
It can yes. And depends on how much you want to spend.
You can, but it will only make it worse. Hogging out already too big runners is not going to help with down low power and air velocity. And you can only get marginal compression by milling those.
Old Sep 23, 2015 | 11:53 AM
Rick1991's Avatar
Ya that makes sense but now if I plan to go boosted I also have a pretty good setup for it because of the lower compression? So many ways to look at it.
Old Sep 23, 2015 | 12:00 PM
redtan's Avatar
Bringing boost in the equation is going to turn your plans upside down. You need a completely different setup for that vs. NA. And it would be tough or downright impossible to have a setup that works great now and later when in boost.
I suggest figuring out what your ultimate goal is. If it is indeed boost then forget everything we just talked about and start off fresh with something that will work for boosted setup even if it's inneficient right now.
Old Sep 23, 2015 | 12:44 PM
lemons12's Avatar
Who said I expected great results.
I got it cheap, so I used it.
I figured it'd do half ***. It did -horrible-.
I didn't have very high expectations at all... It failed even that by a long shot.
The cam was specd by tsp for ls3 heads. It wasn't mismatched on my end. Tsp is just clueless.
Old Sep 23, 2015 | 12:46 PM
lemons12's Avatar
100% the cam. It's just their grind. Not all ls3 grinds act this way.
Old Sep 23, 2015 | 12:47 PM
lemons12's Avatar
Sure it would.. because cathedral heads aren't nearly as picky with cam selection.
Do I recommend going to a cathedral? Sure.
Would his problem get dramatically better with proper cam? Absolutely.
Old Sep 23, 2015 | 01:49 PM
redtan's Avatar
The thing with that is he's kinda dug himself in an hole with the lack of compression, small bore and big heads.
Yes he can get a smaller cam spec'd for those heads/compression to help with the laziness down low...but that thing will fall on its face not much further than the current 5800rpm he has now. If he gets a cam spec'd for better power uptop then it will hurt or keep the same lazy downlow. You can't have both with the current setup no matter how custom you go with the cam.
If he truly wants power everywhere, from 2000 to well past 6000 then he has to do something with the heads and compression. No other way around it.
Which now goes back to the OP and how much he wants to spend to fix this. Get more pep down low he can do it for as much as it costs to do a cam. If you want to improve all over well then he has to spend some money.
Old Sep 23, 2015 | 02:01 PM
lemons12's Avatar
I understand what you're saying.. but a properly specd cam would give a decent bit down low and carry it much farther.
Mine was a 370" with 12:1 cr (+12 dome) and it was still a dog down low.
Tsp is clueless.
If he is half way happy right now I'd be willing to bet John could spec him a cam that would satisfy him until he goes forced induction.
Btw forced induction... Grab some 317s and johns stage 2 or 3 turbo cam and roll. Not much to that.
Old Sep 23, 2015 | 08:10 PM
They are a joke.
What cam?
