reluctor wheel
Old Sep 29, 2015 | 11:49 AM
Slo_balt's Avatar
Default reluctor wheel
I just bought a 08 ly6 that I am putting into my 2000 camaro. I am going to be using my stock computer, and I am concerned with the reluctor wheel. The motor I have has a 58 tooth reluctor wheel and my computer is setup to run a 24 tooth. I'm gonna take it to my local machine shop to do new bearings and rod bolts. So my question is, will I have any problems pressing the 24 tooth reluctor wheel onto my crank? Is there a key way? If not does it have to go on a certain way? Thanks for any help I've searched and I've come up short on the exact answer I'm looking for. Also I don't want to run the lingenfelter box.
Old Sep 29, 2015 | 02:10 PM
BODUKE's Avatar
There is a tool that they should have to put it on the correct way.
Old Sep 29, 2015 | 06:52 PM
Gray86hatch's Avatar
Get the lingenfelter conversion box. The 58x is a better design in every way.
Tim
Old Sep 29, 2015 | 10:13 PM
Slo_balt's Avatar
I don't want to run the lingenfelter box. I don't trust how it works. Does anyone have any personal experience swapping reluctor wheels.
Old Sep 29, 2015 | 10:17 PM
4wheels's Avatar
Default Reluctor wheel positioning
Yes, make sure the shop doing the reluctor swap has a tool for positioning the reluctor. A little off and the timing is wrong. A lot off and it won't run and you will have to take it all apart again.
You can make your own tool/fixture or Goodson and others sell a tool (I think Goodson even claims a patent on the one they sell).
Here is a link to the Goodson one.
BTW - you can put them on backwards too (but you shouldn't).
Old Sep 29, 2015 | 11:49 PM
Slo_balt's Avatar
Well looks like I'll be finding a new shop to do it. They didn't even know if it was directional. I appreciate the information
Old Sep 30, 2015 | 04:11 AM
BODUKE's Avatar
Katech put my wheel on and it wasnt that expensive. I chose to change wheels as oppossed to using the lingenfeltor box. No problems in 2 years.
Old Sep 30, 2015 | 06:10 AM
Slo_balt's Avatar
BODUKE so did you just have your machine shop tear down your motor and send katech just your crank? And do u remember how much they charged you to do that?
Old May 23, 2023 | 09:38 AM
Nova family's Avatar
Default Need help with first ever ls swap
I didn't know anything about crank reluctor ring so I installed replacement engine not knowing they were different so now I want to know if I can reprogram computer from 54x to 24x
Old May 23, 2023 | 12:31 PM
1FastBrick's Avatar
Not on an OEM computer.
If you use a stand alone like a Holley or a mega squirt you can.
