how many use Dexcool or green fluid?
About a week ago, i was checking fluids and noticed the overflow reservoir was empty (the radiator was luckily still full and we had not had any overheating) i didnt see any dripping or puddleing so I got a compression tester and found the small leak coming from the bottom of the water pump. I was thinking the gasket went, but also was reading that our pumps have a weephole that identifies when the pump is going. So i plan to try to find my reciept and get a new water pump (under warranty) and obviously replace the gasket too. But as i was searching online this time around, i came across a thread about dexcool not being good... that it eats away gaskets and some other bad things. It sounded like a few people started changing to the green fluid. So im looking for advice if i should swith to green or keep withthe the dex cool. Also wondering how many have swithed to thr green antifreeze.
