Comp Cams' DTL Lobes
Anyone have any experience with these?
Why not just go LLSR?
Anyway.....if those are LS lobes, I'd get those TFS heads ported (Frankenstein?) by someone who will get them to build flow pass .750" lift. Otherwise, that high lift will be more of an impediment than a asset.
KW
I'll take care of the porting on these heads. If I were to have someone port them for me, I would prefer to use some of the local talent like Greg Good or Rick McConathy.
I don't buy the idea that you can't use a lobe with more lift than your heads can flow to. To me, there doesn't seem to be much going on at peak lift in an engine. The highest pressure differentials are at low-mid lift points. Area under the curve is more important. A 230 lobe with .700" lift will have more area under the curve than a similar 230 lobe with .600" lift, generally speaking. I think that will make more power as long as the valvetrain is happy.
I'm leaning more towards the HUC lobes just for the sake of simplicity. I don't even know if I would have the retainer to seal clearance for a .750" lift cam without going to a longer valve or +.050" retainers/locks.
That's also a LOT of lift for a hydraulic lifter to deal with.....the spring pressure needed to keep the link bar lifter (heavier) as well as the thick *** pushrod in check with a lobe shape that basically KICKS....might as well be in the solid roller territory......
with that being your aluminum engine, a 240/248 LLSR set to zero lash would be quiet as all hell AND rev cleanly to your 7500 target rpm
I'll probably stick to the HUC lobes and a 1.8 rocker.
Just call Kip and have him make you a lobe that will be optimal for your RPM range while maxing out whatever lift you think you can pull off with a stock rocker? Why mess with catalog lobes? He does it for free which still amazes me.
I supposed I could use those rockers in the stud mount configuration if I were to convert to solid roller. At that point, I might as well ditch the EFI and coils and put a carb and distributor on there too lol.
With those rockers, a PAC spring kit, 3/8" pushrods, Caddy lifters, and the cam, I'm looking at just under $1600 including shipping.
For ~$250, I thought I'd give them a try.
http://www.enginelabs.com/engine-tec...-stock-racing/
This pic is interesting to say the least...
