Ls3 swap wont crank and backfires.
https://ls1tech.com/forums/generatio...ngine/1719250-
one-map-sensor-picture.html
https://ls1tech.com/forums/generatio...66-might-have-
swapped-map-sensor-cam-sensor-please-help.html
So update. Took it to the dyno place and the mechanic said that crank sensor is not getting enough signal to fire. This is after swapping another crank with reluctor wheel already in place.
One such is that the 58x(my 60-2) requires a GRAY CS.
The GM 24xe requires a BLACK CS.
This change was not stated.
The 24xe is a EVEN tooth TW with NO missing tooth section, thus no position reference EXCEPT for aid to engine balance.
There is also a chance that the coil "sub-harness" is on the opposite side, though mentioned, not confirmed correct.
Another test would be to measure the voltage at the CS ?
Lance
We had to swap the first half of the firing order for the second half because the cam signal would rise where the 24x would fall. Could that be the issue?
And you're saying the 24x reluctor can't be positioned wrong?
Lance
SSLSLSLSLLSLSLSLSSLSLSLSLSLL
It has to be on correctly or could try to start firing one when the motor is ready for 8 or 2. If it's off to far it will error out or reset the count when the cam signal changes at the wrong moment, but it will start wrong again. Also the sensor needs to match the wheel so he needs the black crank sensor.
Lance
Im using morel 5290 lifters. I don't think it's short travel but has link bar in it. Im not sure which side...I think the driver's side.
Another update..The mechanic contacted one of the GM engineers and claim that he is able to fix the issue. He didn't really specify how but the motor it's assembled ready to be put it on the engine again for the 10th time!!(figure of speech). Please wish me luck and hope this will fix the issue!
This is Adam, I bought that MAF from you at the fire station, I knew Jeremy M. from high school.
Let me know if you're interested in meeting up some day. I'll bring out my LS1 Nova I just finished up.
If the motor runs on a stand then you know the problem is in your harness/ electrical.
If another motor runs in your car or at least hooked to its harness you know the problem is somewhere in your motor.
Not the most practical approach, and would take the better part of a day or weekend, but it would cut your haystack in half and at least give you an idea where your needle is. That's a lot of $$ spent on a new motor to have it simply not work.
I'm relocating my car's computer anyway, if you were in Nashville we could drop it into your car and see what happens. Perhaps someone has a harness and ecm you could borrow for a day.
