Ls3 swap wont crank and backfires.
The issue is that car will not start and it backfires on the intake.
Check:
Fuel pressure. Ok
Sparks. Ok
Signals from cam and crank sensors . Ok
Cam gear was 180 degrees off. Fixed it and still no start.
The only thing left to check without dropping the pan is the reluctor wheel to make sure he installed the wheel right since he tack welded it. The engine builder did not have the tool to replaced the wheel so i sent it to lamar walden to do the wheel swap. Could the engine builder improperly installed the crankshaft and cost the relctor wheel to be off? Or is lamar waldens error?
Any help or suggestions?
Check this post. It shows a reluctor alignment tool. If you do not use something like this, your timing is probably not right.
Ok. So updates:
Brought the car to abother mechanic. He tore down the engine, changed the crank to 24x reluctor wheel. Inspect everything and adjust clearances. Wire everything up and it still wont crank. Wtf!!?
Im this close to part everything out...!
The cam turns at 1/2 speed so if aligned at 12 and 6 and you turn the crankshaft one revolution they would be aligned at 12 and 12. So I don't think that was a problem, You just thought it was.
So no bent valves from misalignment.
