L76 block with 243 heads?
Old Nov 14, 2015 | 01:45 PM
flyin's Avatar
Default L76 block with 243 heads?
Looking at purchasing an engine. The engine is not close enough to look at without going there with the intent to buy. So I have lots of pictures.
The casting numbers aren't conclusive though. The block number is 12577461 but the heads are 243's. The valley pan shows that it has DOD/AFM. Has a truck oil pan and water pump.
What am I to make of this?
Thanks
Old Nov 14, 2015 | 02:46 PM
flyin's Avatar
Info added
Old Nov 19, 2015 | 12:00 AM
LS1MCSS's Avatar
That is the casting number for an L76 block. I wouldn't think those heads were on it from the factory.
Old Nov 22, 2015 | 08:59 AM
Coda634's Avatar
I had the same thing but 799 truck heads.
Replace the oil pan and accessory drive, delete the dod and vvt, and you have an aluminum block LS2.
Depending on the price, you might be better off buying an Ls2. Theres long block L92 (truck Ls3) pull outs on CL for 2500 around me. I would had spent the extra 900$ for the cubes and converted that.
Old Nov 22, 2015 | 07:28 PM
corvette c6 zo6's Avatar
Also my l76 6.0l pontiac g8 has the same .
Old Nov 23, 2015 | 01:07 PM
06blackGTO's Avatar
Hmmm. Yeah that's not right. My 09 g8 gt has ls3/l92 rectangle port heads stock, that's what they come with.
Old Nov 23, 2015 | 01:10 PM
hivoltagedriver's Avatar
The L6 has the LS3 style heads and intake on it from the factory. Sounds like somebody just put a bunch of spare parts together.
The L76^^
