Setting ls7 lifter preload, 7.315 checker plus preload?
So I dropped a stock pushrod in and tightened the rocker down until I couldn't pull/push the pushrod up/down. After that point it took about 1 and a half turns to get to 22ft lbs. Then I took a homemade adjustable pushrod, and came up with 7.315 length at zero lash. With that being said, I add in my desired preload of .085, and come up with 7.4, the factory length.
My question is for starters am I doing this right? I only question it because I figured with the VJ and milling and ls7 lifters I'd end up with something other than stock. I can compress the lifters by hand and they spring back up, so that's why I did the push/pull thing with my fingers rather than setting 0 lash like I normally would. Anyone wanna throw their 2 pennies in?
