Ls7 block
Old Dec 2, 2015 | 04:38 PM
corvette c6 zo6's Avatar
Exclamation Ls7 block
Hi every one i have a question about ls7 engine how much can i go boost with stock lower bottom or should change the stroker ??
Old Dec 2, 2015 | 07:08 PM
SHovV's Avatar
There are several guys over on Corvette Forum that have pushed their stock short blocks to 850+
Old Dec 2, 2015 | 07:10 PM
SHovV's Avatar
850+ RWHP. I know one guy is 13.x compression for E85, turbo'd and sprayed and is making about 980rwhp I believe
Old Dec 2, 2015 | 07:19 PM
gnx7's Avatar
The stock bottom end is pretty strong.... But Ti rods aren't the best choice for big power. If you were to do steel forged rods the heavy Mallory inserted into the crank to balance is properly is $300+ alone. So just sell the rotating assembly or shortblock if you plan to make crazy power
The stock block also has the thinnest sleeves of any alum LS block.... How much power are you looking for. What year z06?
Old Dec 3, 2015 | 01:35 PM
I have zo6 2008 i want just only 700hp.
Old Dec 3, 2015 | 01:36 PM
awesome
Old Dec 3, 2015 | 01:40 PM
SHovV's Avatar
If you're only wanting 700hp, cam, exhaust, cai and some nitrous. Or you could supercharge it
Old Dec 3, 2015 | 02:33 PM
My car has hinson motorsport headers with x pipe and air intake killer bee with hinson shifter .
Old Dec 5, 2015 | 07:07 PM
SHovV's Avatar
So then, cam and a little nitrous, or cam / supercharger. Have you fixed the heads?
Old Dec 6, 2015 | 02:02 PM
BLWN1's Avatar
The shortb lock will bring more running than with a hole in the side...
Old Dec 6, 2015 | 04:48 PM
could you explain what you mean ??
Old Dec 6, 2015 | 05:13 PM
BLWN1's Avatar
It's worthless when the liners are busted and spits a rod... I would play it safe
Old Dec 6, 2015 | 05:14 PM
BLWN1's Avatar
If it was a 500.00 5.3, sure but ls7s will bring decent money I know I need a good one.
