Ls3 polluter/btr stg 4
In my searching I haven't found any dyno results or track times from this cam in a 6.0 (l76). Will the hp and torque curves overlay an ls3 as far as peak rpm (only lower max numbers)? I need to know the info for a converter. Also, I'm sure I can expect the PTV numbers to be tapped out (similar to a 6.2) with no room for milling the heads, correct?
Setup will be around 3200 lbs Rw with a 4.10 gear, a 1.76 glide with a brake and some spray. Hoping this setup can go 9s on a nitrous outlet 200 shot. Seem like a legit goal?
