LS2 question
The LS3 is 8% more displacement 20%+ more head flow, .2 more compression, very similar cam possibly using the same lobes in different combination(Late LS6 intake early LS6 exhaust) and manages 6% more power and according to ALL testing reduced lowend below say 4000ish rpm even on strokers.
http://www.hotrod.com/how-to/engine/...re-port-heads/
Even compared to 317s with less compression and a rectangle spec cam that 20% more airflow only leads to 7% more peak power again with losses down low and according to Brian Tooley the chamber on your existing 243s is so much better than 317s that when they ported a set of 243s and 317 with the same CNC work, then milled for the compression to be equal the 243s made 20hp more than 317s which would greatly close the gap with the LS3 while retaining the lowend those lose.
Yes that stuff will fit, but as an LS3 owner I would suggest you look beyond flowbench numbers and skip the LS3 stuff.
The 6L80E behind the LS3s has a 4.03 first gear rather than the 3.06 first of the 4L60E, that is used to hide the poor lowend response. An SS or Camaro with LS3 has factory gearing(first) equivalent to a 4L60E with 4.10s behind it.
If you believe in only peak numbers and couldn't care less about responsiveness and torque below 4000rpm then again they are something of an upgrade but not that big of one,
and if you value responsiveness and torque at non-WOT rpm levels then no they are not an upgrade.
The 243s are recognized as making more power than 317s due to a vastly better chamber so the difference will shrink, and would shrink again with appropriate cam, and would shrink due to more compression from the 243s vs. ls3s.
Magazine tests are imperfect but it is what we have. Also notable is the torque loss below 4000, again this is on a stroker but I am sure smaller displacement and more shrouded 4.0 vs. 4.03 bore will fix that right?
Now the test is with each having a FAST intake, it isn't stock vs. stock but again it is the test we have.
I went from a Torquer V2 and 243s making 430/390 to a 227/235 cam and LS3 heads making 470/410. The LS3 heads are a good budget option. You just need to verify piston-to-valve clearance due to the larger intake valve and keep camshaft overlap to a minimum if you plan on doing a lot of street driving.
But I will say that I've been very pleased with my setup. Untouched LS2 bottom with untouched LS3 heads/intake/injectors and a fairly mild cam.
I read that to mean the 35hp included the cam, hopefully he will clarify.
Let's not forget the LS2 intake is usually a step backwards from the LS6 due to inconsistencies in the sonic welding.
Taken from another post by this guy.
https://ls1tech.com/forums/generatio...l#post18513634
Here's what I made with an EPS 222/230 .591/.608 114+4, 25% pulley, stock LS3 heads, NO milling, stock gaskets, 1-7/8" LT's. I don't know if it's the cam I'm running or what, but it seems to have a bit more torque than most I've seen. Blue line is with terrible 1.5" shorties and cats. Red line is after I built the 1-7/8" longtubes and catless duals.
I'm really curious as to how much milling the heads .030 (and maybe .040 gaskets) would gain.
When I bought my engine the FAST92 was destroyed in shipping. At that time, LS3 heads were $315/ea and a brand new LS3 intake/injectors take off was $300. So for me is was a no brainer to do this versus buying another FAST intake.
Sounds like you made up your mind based on flowbench numbers alone and can't be bothered with understanding anything.
