LS376/480 Cooling Issue
Attach some pics of your system if you can.
Are you able to move the sensor to the drivers front head too rule out location or is the harness too short?
Try a Lower temp thermostat like a 165 or 180.
Any leaks? This would bleed off pressure and raise temps.
What coolant and ratio are you running?
Also, I know many of those old trucks came with inline 6 poppers. originally. The radiator support usually had a small hole because the radiator was small. You are not blocking 30-50% of the cooling area on the radiator are you by any chance?
Just a few more thoughts. I have seen these situations many times when I worked in a radiator shop many years ago.
Does your steam ports from the engine go to the radiator?
What is the Y setup on the overflow tank?
When ever i fill my engine with anti freeze now i fill through the upper radiator hose and i never have a problem with air. Yours will be easy to do that way.
It could just be the picture but it looks like your engine is level or tilts a little towards the front on the truck. Don't think that is a problem but they are made to tilt back.
Do you have heater hoses hooked up to the water pump? Looks like it in the pic but hard to see.
Been a few months since I checked and I will check again but it did.
Steam ports go to the overflow tank
The Y is for the heater. This was suggested as the best way to plumb it all in since that isn't really an overflow tank but a surge tank I think they are called.
It does tilt back slightly. I tried for 3 degrees.
I do.
In response to Joyridin', The radiator should be plenty big. It is a 4 core for a 500+hp system and I am getting quite a lot of airflow, including that top section showing since the hood on these has a gap of about an inch when closed. The only area of the radiator that doesn't get air flow is that section you can see in the photo so maybe 10-15%.
Completely cold, I turned it on and pulled off my radiator cap and coolant just pumped out. Seems I have blockage somewhere but I need help on where.
Based on this picture, it would seem my thermostat isn't allowing anything past which I assume is normal when cold and closed but isn't there a bypass? Maybe I am wrong. I have always been able to open my radiator cap to verify flow without an issue. But I have never done it in an LS. Do I have to wait for the thermostat to open before I can verify flow?
Any help?
I allowed it to build heat up to 215 and all temps except lower radiator increased proportionally. Then steam started pouring out of the middle of my radiator. No hissing or anything but coolant smelling steam front and back. Guessing I blew a leak somewhere.
It sure seems to me that I am not getting the flow either through the radiator or through the thermostat. Revving the motor cools it down and increases pressure due to faster running pump. Is the logical conclusion that my radiator is not flowing properly?
This is the radiator I was using. Only 3 core but rated to 650hp supposedly.
The temp reads on my thermostat housing were very low but I assumed it was just because it was thicker aluminum. I also noticed the 3/4 heater in line was reading about 150 when everything else was 195. All of that might mean my thermostat is not opening.
Wish I had figured this out before blowing my radiator. Now I am dead in the water until I figure out a new radiator. Hesitant to go with another Champion.
Many thanks to all that gave me ideas and especially to 427 zeo6.
If you want OEM, I have also had good luck with C4 Corvette radiators. They are super light and the inlet and outlet are size perfectly for the LS engine. If the size works for you, I'd go with that. Also cheap.
Andrew
