LS376/480 Cooling Issue
The cooling system is a 4 core radiator, surge tank and front 2 steam ports routed to the surge tank.
Any thoughts? The obvious seems that the water pump isn't circulating fast enough at low rpm's but that doesn't make sense given I am using the recommended gmpp combination of parts.
The computer was provided by Speartech. I originally used gmpp everything but had lots of issues with the wire harness. Dumped all of that and am now running a Speartech harness and computer.
I also know my temps are actually changing because when it gets higher it will release the cap on my surge tank.
Someone correct me if I'm wrong.
Interestingly I wired in a switch on my fan to turn it off on the freeway to see if it running all the time on the freeway was necessary. It didn't change the temp at all having it off on the freeway but it doesn't drop enough to automatically turn the fan off unless I run in 4th gear and get the rpms up.
I've had good luck with backfilling the system through the vent hose. Attach a 2 foot hose to the crossover nipple, use a small funnel. It's a slow process but works well in completely filling the block and purging any air that might be present.
Andrew
