Ly6 questions!!
Old Dec 22, 2015 | 09:37 PM
md93's Avatar
Default Ly6 questions!!
Ive got an ly6 going in my 95 camaro and have got a few questions.
I am going to run a 2002 camaro ls1 computer and engine harness so I need to change the reluctor wheel to 24x. Any solid threads on this? Seems like a nightmare at this point.. Do I need to mess with the cam gear also?
As for the engine harness could I use this one from summit?
http://www.summitracing.com/oh/parts...ngine-swap/yes
And yes you guessed it the VVT is next… I feel like it has a ton of potential increasing the power band and being more efficient.. BUT as a weekend cruiser drag car is it really worth keeping? Im leaning towards chunking it so I can do an easier, less expensive cam swap.. Thanks for any info!
Old Dec 25, 2015 | 06:29 AM
alocker's Avatar
You either have to pull the crankandswap the reluctant or get a converter box. Yes,you will also need the cam gear which means bye bye vvt. knock sensor location might need to be addresses too.
Old Jan 3, 2016 | 08:46 PM
jimmyg's Avatar
Talk to psi buy a harness and e38 ecm to run the ly6 . psi conversions it will be a lot easier and cheaper in the long run
