lifters ls
Old Jan 8, 2016 | 01:05 AM
Tknz's Avatar
Default lifters ls
Hi, need help
ran into trouble last night assembling engine, had purchase some dyne time 5206 morel lifters (supposedly)
some of the lifters don't fit in the bushes, they seem to be spread at the rollers.
i now need new lifters new 5206 might be out of range.
3.926
2.7 crank
mast small bore heads duel spring
cam is 0.629 in 0.621 ex
duration 220 230
lsa 114
engine runs at 6200 for an hr at wide open 15psi v1t vortech.
what lifters will be durable for me?
Thanks
Old Jan 8, 2016 | 01:33 AM
juniorssrollin's Avatar
I just ordered Johnson 2116SLR from BTR. They are a tad cheaper than those Morels and after reading what felt like 100 pages, you don't find any failures.
Old Jan 8, 2016 | 02:28 AM
Tknz's Avatar
had a look for them, are they on the shelf anywhere? seem to be an order deal
Old Jan 8, 2016 | 05:08 AM
Just go to Brian Tooley Racing website
Old Jan 8, 2016 | 12:48 PM
Tknz's Avatar
Just been on btr, next and final question, the drop ins use the trays are 150 cheaper than the linkbar, same Lifter, is the linkbar version worth the extra $$?
Tom
Old Jan 8, 2016 | 01:07 PM
Havoc40's Avatar
I'd recommend 2116's for this application. Once you factor in new trays (which is always recommended) you're looking at a $118 difference. Yes, they're worth that difference. The internal design and travel are suited perfectly for sustained WOT without worrying about oil aeration and pump-up.
Old Jan 8, 2016 | 01:28 PM
Droptopws6's Avatar
Is the engine in a boat or something? 6,200 RPMS for an hour, whew!
Old Jan 8, 2016 | 02:04 PM
Tknz's Avatar
Boat yes, are my morels I have now useless to me?
Old Jan 8, 2016 | 02:48 PM
Havoc40's Avatar
If you have micrometers, measure the bottom ground surface. Usually you can go just below the axle at like 30* to the axle. Then measure the top ground surface. Post the numbers back in this thread. If it's anything over .0005" difference, I wouldn't use them. Most of the time they're worse than that when they spread, though.
