L33: worth rebuilding?
I own a 2007 NNBS 1500 Silverado with the L33 engine that currently has 204k on the ticker in 100% stock form. This engine has been great to me so far with little maintenance besides replacing lifters and pushrods at 198k.
My concern: Knowing this engine wont last forever...is it worth rebuilding an all aluminum engine with high mileage and probably more wear than I can tell? I've always gone by the saying "if it ain't broke, don't fix it"..but I do like to be prepared with a plan when the sh*t hits the fan.
The truck has been paid off, and cosmetically doesn't show its high mileage which is why I'm willing to go a few extra steps to keep this 1500 for years to come. So I suppose what I'm getting at, is if I do rebuild, it will be for performance. Shooting for a "reliable" 500 crank hp (N/A) is the goal. I don't want to step up to a 6.0/6.2 etc either. I know this will sound contradicting , but durability and longevity are also a must even with the HP goal in mind.
My initial thought was to go all out with a fully forged iron block, rather than potentially spending money on high mileage aluminum block that won't last... Do it right the first time, even if the cost is higher. In addition to a bottom end rebuild, I would either have the heads completely redone (which appear to be in "fine" shape, or buy new.
Before it gets brought up, I'll be building the truck from back to front. It will have a 14 bolt FF rear, and 4l80e transmission by the time the new or rebuilt engine goes in.
So to sum things up: 500hp crank goal built for durability and longevity.
To rebuild the L33...or go for a fully forged short block?
Thank you in advance for the input/advice/etc etc!
Any votes on just saying screw it, and doing a junk yard 5.3 and ebay turbo for a relatively cheap/easy 500 crank hp?
