First time LS Build
Old Feb 9, 2016 | 10:31 PM
Aaron1989's Avatar
Default First time LS Build
As stated, this is my first time building an ls motor. I have a 2000 6.0 LQ4 with the stock 317 heads. My HP goals are around 400rwhp. No plans as of now for any kind of forced induction. I would like to go with some 799 heads as i can get them from a buddy for almost nothing. what would be the best route to go with the 799s? keep them stock or mill them for a higher CR? I would also like to go with the TSP 228r cam (228/228 .588"/.588" 114 LSA) as i can get it secondhand for cheap also. will the stock 799s do ok with this cam? I already have an ls6 intake and TB. so with the 799s, cam, and intake; should i be at my desired goal?
Thanks in advance! -Aaron
Old Feb 10, 2016 | 09:50 PM
Aaron1989's Avatar
Also, if i keep my 317s and mill them down about .030 i should be around 10.5:1 CR right? would i run into PTV issues with a .600 112LSA cam? i plan on keeping the dished pistons. so would milling .030 with the .600 cam and ls6 intake get me to my goal?
Old Feb 11, 2016 | 12:56 AM
gnx7's Avatar
Run as much compression as possible.
91 can easily do 11.25:1
93 does 12:1
That is a tiny cam in a 6.0. It'll drive nice.... But won't be nasty. The power is in the heads. Ported stock casting heads gain 30-40rwhp over non ported. Long tubes are a must.
