Big under performance on dyno
Old Mar 9, 2016 | 06:51 AM
maroonls1z's Avatar
Default Big under performance on dyno
Finally got the car on a dyno yesterday and i felt like i was around 70hp/tq short. Was hugely disapointed. We did a balance test and it didnt show a down cylinder. How should i go about evaluating for this because i think something is very wrong. Motor is a 434 ls7 with stage 2 heads by westcoast cylinder heads cam is 228/240 650/652 114 portedfast 102 by mamo with nw 102 tb and 2" primary header into 3" true duals and 11:8:1 compression. Got 510hp/505tq
Old Mar 9, 2016 | 09:44 AM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Auto? Or Stick? Drivetrain?
Can you post graph? Where are the peaks?
Who specced the Cam? Looks a little small for
434", I would have gone at least 235*/247* depending
On your goals even up to 243*/258*.
just my .02
Good Luck
Old Mar 9, 2016 | 09:58 AM
maroonls1z's Avatar
Mamo speced it. T56 through 9" with 3.50 gears. Wanted something i could dd without issue. Dont have the graph. Ill get pat g to email it to me. Peaked around 5800
Old Mar 9, 2016 | 10:10 AM
KCS's Avatar
KCS
Moderator
The 228 intake lobe seems pretty small for a 434ci LS7 engine. You can run more duration than that in a daily driver with Pat G tuning it.
Old Mar 9, 2016 | 10:15 AM
maroonls1z's Avatar
I wanted something not too lopey. But with everything considered i still figured over 550
Old Mar 9, 2016 | 10:22 AM
BLINGOLE's Avatar
I think it should be around 570rwhp, but not with that cam. That cam is more of a stock headed ls3 spec. What brand dyno?
Old Mar 9, 2016 | 10:27 AM
blk00ss's Avatar
Yeah that's a baby cam. F that.
Old Mar 9, 2016 | 10:29 AM
maroonls1z's Avatar
I wanted a baby cam, but with my supporting mods barely scratching 500 seems like a joke
Old Mar 9, 2016 | 10:44 AM
tadams72's Avatar
That's a pretty big number for such a mild cam on a 434 but there may still be some room for improvement in the tune. Wait to see what Pat says and post the chart. Interested to see how it shakes out. Once it is dialed in properly I am betting it will be a lot of fun on the street.
Old Mar 9, 2016 | 10:48 AM
maroonls1z's Avatar
We were talking last night and he said my intake was pretty restrictive and we ran it open tb and it did bump to about 530
Old Mar 9, 2016 | 10:59 AM
blk00ss's Avatar
Well how about posting the rest of your setup
Old Mar 9, 2016 | 11:00 AM
maroonls1z's Avatar
104mm lid. I dont know of anything that flows better than that?
Old Mar 9, 2016 | 11:28 AM
KCS's Avatar
KCS
Moderator
How many NA engines do you know of that make 550whp with a 228 intake lobe? I think that's pretty unrealistic.
If you wanted a 550whp daily driver without lope, you probably should have built something with a blower. I've seen bone stock LS9's make 510whp on a Mustang dyno.
Old Mar 9, 2016 | 11:30 AM
blk00ss's Avatar
No it should be fine. Mine didn't pick up hardly anything by pulling the air filter. Are you speed density? And when you say 3" duals, what exactly are they? What mufflers? Where do they dump? And what brand of headers? What does your valve train consist of? What tires did you have on? Did you say what dyno? Have you took it to the track yet?
Old Mar 9, 2016 | 11:34 AM
blk00ss's Avatar
Yup!!!
Old Mar 9, 2016 | 11:42 AM
maroonls1z's Avatar
Was on toyo r888, kooks ceramic coated with kooks true dual. Che bushed rockers with johnson limmeted travel lifters
Old Mar 9, 2016 | 11:43 AM
maroonls1z's Avatar
Was tuned litterally last night so no... No track time. Mustang md250 dyno
Old Mar 9, 2016 | 11:48 AM
MuhThugga's Avatar
I think you should be happy with the results. You can't say that you want a small cam to maintain stock driving characteristics and then expect huge numbers from a naturally aspirated engine. The fact that your horsepower peak is at 5800 RPMs shows that the cam is on the small side of things for that engine. However, look at your peak torque number. I'm willing to bet that the torque curve stays consistently flat throughout the RPM range.
Don't worry about the peak numbers so much.
Old Mar 9, 2016 | 11:51 AM
blk00ss's Avatar
That's probably closer to 530ish on a dyno jet. So I would say it's really about right with that small *** cam.
Old Mar 9, 2016 | 11:54 AM
maroonls1z's Avatar
I guess ill see what i can do intake wise to get closer to that 530 we got when we took the intake off
