Spec me a cam!
2002 SS
Plate kit on a 200 shot
Built 4l60e
3800 stall
8.8 rearend - 4.10 gears
Bigs and Littles
LS2 Block
4.020 flat top pistons
Hell fire Rings gapped for a 250
LSA rods
LS3 Crank 24 tooth reluctor
706 heads
milled .020
Ported
243 Valves
ls9 head gaskets
ARP head Studs
Ported ls2 Intake
Nic Williams 92mm tb
239/254 .624"/.595" 114+3 would work better with better heads. But 402 + nitrous... and that cam would work well.
Either way, something with a heavy exhaust bias for NO2, like what JakeFusion mentioned.
good rule of thumb is to treat spray like a blower, you dont want the spray blowing out the exhaust side with a huge overlap NA cam. You will have alot of exhaust volume that you have to get out so you want a big exhaust side without overlapping alot.
I also like that cam that Jake posted above for your combo. Looks like it would work well with your setup.
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
