TDC vs Base circle
Old May 10, 2016 | 03:36 PM
mr08353's Avatar
Default TDC vs Base circle
When a cylinder is at TDC, does that mean the cam is also at base circle for that cylinder? If not, how do you determine base circle on cam? (For setting lash to zero)
Old May 10, 2016 | 04:59 PM
KCS's Avatar
KCS
Moderator
First question: yes and no. Both valves are open at TDC between the exhaust and intake strokes, but they'll both be closed between the compression and power strokes.
Second question: EOIC Method. Google it.
Old May 14, 2016 | 08:24 AM
140K_GXP's Avatar
Yep, EOIC method.
Old May 15, 2016 | 08:13 AM
BOLO's Avatar
The best way as mentioned, EOIC method.
