LS7 Sneak Attack by Katech
I'm really interested in the dyno charts of this build. Although quite expensive (I think Katech MSRP was $25,000), this engine might have some significant advantages over many LS engines (especially on boost).
Unless you have some heads flowing some serious air with an intake that can support high RPM's (no stock intakes or MSD/FAST etc are going to support high RPMs) plus a solid roller cam setup and nice rocker arms this isn't even worth attempting. Dry sump also for oiling safety.
Unless I'm wrong, the LS7 heads and intake would work at high rpm's considering the 5.7L displacement. Now running 7.0L displacement would be a different story...Plus, I would be running boost so stuffing that air in shouldn't be a problem.
I would be running premium valve train with Cadillac CTS-VR lifters.
Am I missing something?
BTW Nice vids/car!!
Plenty of people have pushed stock stroke 3.622" cranks to 8000rpm. Unless you are shooting for more than that you are giving up low end power. Also solid roller lifters $700 and rocker arms are needed to take advantage of high rpms in conjunction with an intake manifold that can flow up there vs. hitting a bottleneck shortly after 6600rpm which most intakes do.
"So I've been doing some 'back of the napkin' calculations.
Normally, a longer stroke gives a mechanical leverage advantage (well, it ALWAYS does if the force on the crank's rod journals doesn't vary when comparing different stroke lengths).
However, cubic inches being equal, a larger bore can produce more torque on the crank if the bore is large enough. However, it would not be very cost effective.
Using an LS7 block with 4.125 bore, you could build a 349 ci using a 4.8L 3.267" crank.
Assuming compression ratios are equal between this theoretical engine and an LS1 (therefore peak cylinder pressure at detonation is equal), the theoretical engine would place more force and rotational torque on the crank even while having a shorter torque arm (shorter stroke).
Again, I doubt that anyone would want to build this due to the cost, but imagine how that engine might perform if you were constricted to 350 ci!! More torque and way more rpms/high end HP! Also, this engine would likely see improved fuel economy over an LS1 due to longer rods causing more dwell at TDC and more complete efficient combustion of air/fuel mixture.
Please correct me if I'm wrong.
(Peak cylinder pressure)x(piston surface area)x(crank stroke)=rotational torque"
Katech Jason, I discovered the Sneak Attack after coming to this conclusion...therefore my interest. Thanks for your reply to my email! However, I don't think I could justify the expense unless it was on scale with other LS engine builds.
I'm not following you when you say that a shorter stroke won't allow an RPM advantage. Could you please elaborate? I would greatly appreciate it and don't worry if the discussion becomes very technical...that's not a problem.
The 4" cranks have no problem turning RPM. Joe Honeycutt was turning over 10k RPM with an 6 counterweight crank years ago. The shorter strokes may be able to turn higher, but you will never be able to turn that high. You will be limited by the valvetrain before the crank.
But, I would be running the same valvetrain that Jason Katech described...with Cadillac Racing CTS-VR lifters (good for 8000-8400 rpm's). This has been done before with the 5.7L LS7 Katech Sneak Attack.
I would just need to figure out how to do it without spending big bucks. The shorter stroke and longer rods would lend to longevity.
What kind of budget are you working with? What application is the engine going to be used for? What chassis?
Man, I don't want to argue with you. You obviously have a lot of experience.
If you compare the air volume passing through a 7.0L LS7 stock composite intake @ 7000 rpm and the volume at 8000 rpm with 5.7L LS7, you will find that the port velocity is LOWER with the 5.7 @ 8000 rpm (I can provide the calcs if you want).
I would like to place all of this in a 4th gen Camaro just for the hell of it.
Maybe I could beat the 4th gen Camaro that set the Texas Mile record (for any Camaro) of 263 mph!
I know because I recently built a short stroke bbc and paid a little more for a little less. It still made 810hp so who cares, lol.
