Lq9 l92 heads ?
Old Aug 15, 2016 | 04:13 PM
Dgiorgi34's Avatar
Default Lq9 l92 heads ?
I'm putting a motor together for my SS pick up. Larned a lot from you guys on here already👍. My question, can I use my head internals from my factory lq9 on a set of l92 heads? I'm also planning on a ls3 intake manifold and TB. Am I gonna run into any problems? Or is it really that easy? I just want to have all the parts ready. Thanks guys..
Old Aug 15, 2016 | 05:06 PM
xdanny510x's Avatar
Ur gonna need off set rocker arms n pedalstals
Old Aug 15, 2016 | 05:43 PM
Dgiorgi34's Avatar
Default Yea
Is that is all that is needed? Seems too good to be true. Parts are relatively cheap for what people are claiming to pull out of this setup.
Old Aug 15, 2016 | 06:52 PM
xdanny510x's Avatar
If ur gonna go with the l92 heads this is what u need.. the intake manifold. Rocker arms. Pedalstals .. gaskets.. injectors. Fuel rail. Injector adapters. A good camshaft suited for those heads..
Old Aug 15, 2016 | 08:01 PM
EvoByDarwin's Avatar
Just make sure whatever cam you choose has enough PTV clearance.
Old Aug 15, 2016 | 09:54 PM
Dgiorgi34's Avatar
Ok awesome, thanks guys.👍👍
Old Aug 16, 2016 | 01:07 AM
Tuskyz28's Avatar
The PTV is critical on these setups as already mention... if you don't want to really "worry" about it go with a 230 or less cam on the intake duration......
