L92 build opinions
This is going in my 2001 Camaro, 4L65E Trans, 3.42 Gears, P59 Truck PCM. Going to tear the engine down too install a 24X reluctor.
LS3 Intake.
LS3 Throttle Body w/ X-link box.
GM LS3 Head Gaskets.
GM Head Bolts.
LS7 Lifters (12499225)
LS3 Timing Cover
LS2 1x Timing Gear
LS2 Timing Chain Damper.
Hinson C7-R Timing Chain.
Low mileage L99 Balancer.
Comp XER273HR-14.
Jegs .080" 7.400" Push Rods.
PAC 1904 Dual Springs w/ Steel Retainers.
Questions are......
Do I really need to change the Intake Valves? A lot of conflicting information out there, Some say it's the pistons hitting the Valves/Loss of Valve Control, Some say it's the 2-piece construction & the heads just pop off.
It is my understanding that VVT-L92's have a high volume oil pump & will suck the sump dry? Running a stock F-Body 5.5 Quart Oil Pan......
Any & all thoughts/opinions welcome.
LS3 Intake.
GM Head Bolts.
LS3 Timing Cover
LS2 1x Timing Gear
Comp XER273HR-14.
Questions are......
I haven't seen or heard of a real case of a high volume pump sucking a pan dry yet. For daily driving and drag racing, it should be fine. For road course or top speed competitions (TX mile for example), it may happen. I had a Melling 10296, which is in between a stock LS1/6 pump and a VVT/AFM pump, on my old Trans Am engine and never had an oil pressure/level problem.
And please, do not buy pushrods all *****-nilly. Measure for correct length and preload.
Other than that, it all looks pretty good.
LS3 Intake.
GM Head Bolts.
LS3 Timing Cover
LS2 1x Timing Gear
Comp XER273HR-14.
Questions are......
http://store.cammotion.com/parts/valve-spring-kits
For the camshaft, have a look at our Titan Series street performance camshafts:
http://store.cammotion.com/catalog/s...word=titan+LS3
Our lobe designs and springs kits are compatible with your L92 valves and give outstanding performance. If you have any questions about camshaft selection for your application, it would be my pleasure to help you.
~Steven
The Cam & Pushrods are the ONLY 2 things I had laying around & didn't have to buy!!Definitely going to check the length, If I have too buy different length one's.....I'm not out any cash.
The cam came out of a 2011 LS3 that was running Beehives with no damage!! I was thinking running a good set of Duals would help control things better? The recommended Spring on Comp's website for this Cam are Identical to the PAC 1904 Specs.
The cam you mentioned sounds a little big for my needs.....Keep in mind I build Transmissions, I know just enough about Cam Specs to get me in trouble.
I have 3200 Stall now, And I DO NOT want too re-stall the 4L65E as a 4L80E is planned in the future.
KCS stated I may be able to get away with this IF LS3 Valve are installed......I can do that! I can get them from my local Chevy house for $23 a piece.
I don't mean to be a cheapskate, But I have a daughter that just started College & 2 daughters in High School.
I also hate the stock crank vibration damper/pulleys. Lots of guys run them I know, but I have killed two of them. Not sure if it is the Florida heat or the countless trips to 7,000 RPM, but my ATI damper is money well spent in my book.
