Push rod and timing chain
Also, you always have to measure for proper pushrod length when doing a cam swap, head swap, new head gaskets, etc. Most aftermarket cams have a smaller base circle versus a stock cam so longer pushrods are usually necesarry. But there is no way to know ahead of the install what length pushrod you will need. You need to measure.
