Forged???
And I guess the pistons may need to be forged also???
Compression, RPM, desired usage etc. all play in a big factor.
For example, a 14:1 8000rpm engine with 500hp will definitely need quality forged components if being constantly used at WOT and 8000rpm. Now the same 500hp but stock compression and used as a daily driver won't.
The engine I have is a L96 out of a '10 Express Van. It was completely dismantled when I bought it. That is why I thought I would ask you guys about upgrading to forged parts before I start reassembling.
Hey JoeNova, I would like to boost it at a later time, you recommend a ring set or cam?
Cam will depend on the entire setup as a whole. Turbo size, turbine A/R, twins, single, displacement, heads, etc.
I have no clue on turbo size and such. I think I want a single turbo? Its a 6.0, so 364ci. Heads are bare 823's at this time. Will need valves, springs... Intake is the stock truck.
