Good universal cam degree kit?
I'm looking to get a kit so I can degree the cam and make sure it's installed right in my LS3. It has 4 degrees advance built into the cam, and I want to make sure it's in it's proper place when installed. However, this will probably be the only LS engine I work with for quite some time, and I feel like $180 for a specific LS/small block kit would be wasted after one use. I see kits like the Trick Flow I listed go for less, are "universal" for all cams and can even work with setting up gears in differentials. I'll be swapping in a big block in my truck, and rebuilding the rear diff, so this kit would be very ideal for me. I don't mind spending money on a good kit that I will use multiple times, I just hate spending money on one tool and never use it more than once.
https://www.summitracing.com/parts/tfs-90000/reviews/
So I used the kit to degree my cam. Great kit for the money, I like the quality and the setup. My only complaint is that I wish I bought a bigger wheel, the accuracy was fine, but it would be nice to have a big solid wheel to grab on to and spin the rotating assembly to get the measurements more accurate and control the spinning. However in my case I don't plan on working on another LS engine anytime soon, so this still works out. If you LS everything or work on them a lot, I would highly recommend a kit with a solid and bigger degree wheel meant for LS engines.
