Simple DOD Delete Question
Old Sep 28, 2016 | 08:14 PM
TNspeed1's Avatar
Default Simple DOD Delete Question
I have a 5.3 iron block out of a 2007 Tahoe. I am in the process of pulling parts together to rebuild the motor over the upcoming winter months. I just picked up a LS2/3 valley cover to do the DOD delete. My question is what do I do with the back threaded hole? Does it get blocked off? If not what sensor goes in there? I understand that the front line will go to the intake. Please take a look at the picture below. I appreciate everyone's help.
Save
Save
Old Sep 28, 2016 | 09:26 PM
S10xGN's Avatar
Oil pressure sensor goes in the threaded tower. I have valve cover breathers on mine, no PCV system...
Old Sep 30, 2016 | 06:51 AM
TNspeed1's Avatar
Thank you for your response. Should I use an oil pressure sensor from a 5.3 or and ls2/3?
Old Sep 30, 2016 | 07:29 AM
JoeNova's Avatar
Restricted User
AFAIK, zero different between the sensors.
Old Sep 30, 2016 | 07:54 AM
TNspeed1's Avatar
Thanks. I was just looking on Summit and it looks like they should be the same. I didn't know if one was taller than the other due to the differences in intake heights.
Old Sep 30, 2016 | 09:11 PM
ls1charged's Avatar
i thought the ls3 cover was different then the ls2 and only the ls3 will properly get rid of the DOD?
Old Sep 30, 2016 | 09:59 PM
S10xGN's Avatar
The bottom of that plate has o-ring grooves to seal the oil towers, or if the engine is apart, the towers can be drilled & tapped for 1/8 npt plugs...
Old Sep 30, 2016 | 10:23 PM
ls1charged's Avatar
gotcha, i know the ls3 cover had rings just didnt know the ls2 did
