GM LS Hot Cam & Springs
We own a brand new LS3 Crate Motor from GMPP. A GM LS Hot Cam is being installed at this time, Hydraulic Roller, Duration at .050 in. 219/228, Lift .525/.525. The kit came with a set of LS6 springs. It is my understanding that the LS3 springs do not need to be changed. Is this correct? It is going to be an off-road engine, and will never go above 4500rpm.
Thanks for your help!
Yes your standard LS3 springs would be sufficient with the GM Hot Cam.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
Some of us have better things to do than change valve springs every year. I bought a crate with a HotCam for my Miata. I'm replacing it with an ASA cam this winter ... another "tame" GM cam that won't require any extra maintenance. I can just drive the car, which is how I like it.
GM cams easy on the valvetrain
The following users liked this post:
67hotrod (10-16-2020)
