Can't decide between ported L92s vs PRCs 237!
PRCs :
https://www.texas-speed.com/p-1171-p...der-heads.aspx
L92s :
https://www.texas-speed.com/p-1179-p...ted-heads.aspx
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
Thanks
John J
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Would this same assesment be true for the PRC 237's vs ported 823's on a 13:1 416? Also how would it perform with the 237's at a 64cc combustion chamber size?
What if I milled the LS3 heads to match the 10.9 CR?
And any time you can have similar flow through a smaller runner, that's a no brainer
The LS3 heads have the same effect as the 237s would due to size. If you were to mill them down to gain the compression back you would kill a lot of piston to valve clearanc e preventing running a large camshaft.
JayTS, to answer your question I feel like its hard to compare because at that point the intake manifold becomes a serious question. If you put a good sheet metal manifold on top of the LS3 heads and try to rev it high I would expect a larger peak number due to more flow. With most street intakes I would lean towards the 237 because LS3 street intakes are bad, whether you talk about FAST or stock.
For that setup I would almost want to look at the 247 head we have. At that kind of compression, and assuming a good intake is on there the 247 would do better. We have a 14.5:1 416 solid roller motor with 247s and a ET 2 piece intake in one of our race cars right now, last engine dyno was 760+ so cathedral will definitely perform.
So to wrap it up, here is my plan :
PRC 227 heads
Fast 102 intake
Camshaft : 223/229 - .629/.629 @ 115+4
1-7/8 LT headers with no cats.
T56 M6 with 3.42 rears
I'm now ready to pull the trigger on this deal!
Texas Speed : Expect my call on next Monday morning.
To add on to my setup, it will be in a lightweight RX7 and intake manifold was limited at best being a Tony Mamo ported FAST 102/NW 102 to compliment the 64cc PRC 237's, Johnson 2116 Limited travel lifters, and a custom hydraulic roller BTR cam (243/262) and of course being a 417ci shortblock. If I was going to change I would go with the PRC small bore LS7 heads and a LLSR cam setup. Wish I would have gone with the 247's but I got a deal on the 237's. Thanks again!
