Valve clearance
Old Nov 15, 2016 | 04:39 AM
2KGRM9's Avatar
Default Valve clearance
Can a .612" cam be installed without a valve relief? I know timing makes a difference, but I am fishing for a general answer. Our .560"lift cam has zero clearance issues.
Old Nov 15, 2016 | 07:29 AM
KCS's Avatar
KCS
Moderator
Yeah, depending on the valve events.
Old Nov 15, 2016 | 08:23 AM
KW Baraka's Avatar
Originally Posted by 2KGRM9
Can a .612" cam be installed without a valve relief?........
Yep.....we need you to provide more than JUST valve lift.
As a point of reference, I run .668" lift (1.8 ratio rockers) with a stock LS3 short block and ported OEM heads.
Jus' sayin'.......
KW
Old Nov 16, 2016 | 07:56 PM
2KGRM9's Avatar
Jus' sayin'.......
KW
Without added valve clearance???...this is very good to hear. We will check it but was hoping the valve angle was working for us...
Old Nov 17, 2016 | 10:20 PM
KW Baraka's Avatar
Again.....lift is a small part of the equation in regards with valve clearance.
You can have valve clearance issues with .500" lift if your valve opening and closing events are off.
THAT'S WHY you need to provide the cam's specs if you want anyone here to help you!
KW
Old Nov 18, 2016 | 09:50 PM
STANG KILLA SS 2's Avatar
TSP makes two .655 lift cams for stock LS7s
