Tune needed after milling heads? /+ compression
Old Nov 18, 2016 | 02:52 PM
STANG KILLA SS 2's Avatar
Default Tune needed after milling heads? /+ compression
sent LS7 heads off to AHP for moldstar90 guides, hollow SS valves, valve job, no porting. im also having them mill the heads .025" for a little compression increase.
will i need a retune after this? technically the air/fuel ratio shouldn't have changed i wouldnt think? but ive heard people mention a .030 mill on a LS7 is good for 20hp.
Old Nov 18, 2016 | 05:29 PM
NHRAFORMULA00's Avatar
i would have the tune touched up.
Old Nov 18, 2016 | 05:35 PM
Dyno Junkie's Avatar
I had .075" machined off our LS3 heads and whilst it did drive fine we did have the tune touched up later.
Attached Thumbnails Tune needed after milling heads? /+ compression-image.jpg
