9.260 Deck height effect on compression ratio
I tried to figure out what my compression would be or more importantly how much effect the .20 ci volume would have on lowering the ratio, but I am not confident in my math. I think I figured that it would add 42.5 cc to the cylinder volume if punched to 4.065 and slightly more if I do 4.125. (Its obviously no big deal to have it cut down but I don't like to machine away metal if not needed)
I would be running CNC ls3 heads. I think these are 70cc. I haven't bought a rotating assembly yet so that is still open. Is it viable or possible to leave the deck alone and run higher compression pistons, or is this not practical or give me too low compression? Thats assuming the deck finish will be good enough to leave alone. It looks pretty good to me but haven't done any checks.
I would "spec" .025"
I can supply the CORRECT RacTech piston.
I can supply the Crankshaft and Forged Rods.
Lance, BTW, at great price !
Thus I will pass on that, don't agree, using another instance.
I will provide two reasons of benefit, there are more :
1. Most SC engines have a lower compression ratio, hence a lower combustion gas temperature BEFORE the Spark Instant.
The action of Squish, the term states a "pushing" of mixture generally into the center/plug area, adds heat to the pre-combustion gases.
This is MOST important when the engine is throttled, when there is VERY LOW cylinder pressure.
This effect has a great influence on BSFC with the ability to run a higher AFR, good for fuel consumption reduction.
2. The Quench (Squish) area runs at lower temperature, the crown/head area that is in close contact.
This effect is VERY good for top ring land life, the area that pre-ignition is born.
The old story "HP sells engines, Torque wins races"
Lance
