Impressive results from the PRC 227 heads!
Old Dec 18, 2016 | 04:17 PM
Kamaro's Avatar
Default Impressive results from the PRC 227 heads!
I swapped in a new pair of PRC 227 heads and a small custom grind cam spec'ed by PG (223/229 - .629/.629 @ 115+4) along with a FAST 102 intake with a stock 90mm throttle body. I got the car dyno'ed yesterday and I got 445 RWHP and 442 RWTQ and that only to a 4500 RPM pull because the stock LS2 injectors were maxed out!, my tuner said it will easily pick up 30-40 hp more if I had enough injectors. All that with a 1 7/8 LT headers to 2.5 in exhaust.
Well, these PRC heads gave me what I was looking for and some more!
Thanks for the guys at Texas Speed, they were very helpful both here in the forum and on the phone
Old Dec 18, 2016 | 05:23 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Excellent results from a well put together combo, like the cam specs.
Old Dec 20, 2016 | 08:15 AM
CAMSTER's Avatar
This an ls1?
Old Dec 20, 2016 | 10:00 AM
Kamaro's Avatar
Originally Posted by CAMSTER
This an ls1?
Its LS2
Old Dec 21, 2016 | 09:07 AM
farmington's Avatar
Something doesn't seem right here. Hmmm
Old Dec 21, 2016 | 01:16 PM
Kamaro's Avatar
If you've noticed anything off here then please let me know. I'm definitely not an expert here and I'm willing to know more about my engine.
Old Dec 22, 2016 | 11:31 AM
etekberg's Avatar
445hp @ 4500 rpm = 519 ft-lbs torque
Old Dec 22, 2016 | 12:44 PM
farmington's Avatar
At 6500rpm that motor would be at approx 600+ rwhp. Not.
Old Dec 22, 2016 | 01:10 PM
JakeFusion's Avatar
Super Hulk Smash
Sounds good. 440rwtq and 490-500rwhp seems possible on the LS2 or 6L motors with good heads.
