LS3 Valve Spring Upgrade (drop in)
Old Jan 4, 2017 | 09:11 PM
Justhereforinfo's Avatar
Default LS3 Valve Spring Upgrade (drop in)
I'm looking for a Valve spring with a 130# on the seat, and around 320# open, that will drop right into my stock ls3 heads. It's not a very aggressive cam, and these are the spring pressures it calls for.
I'm just curious if anyone here has ever used the Trickflow Racing (by PAC) spring # TFS-16918-16. Summit sells them for $140ish and according to this document, they fit the stock retainer and locks.
https://static.summitracing.com/glob...s-16801-32.pdf
And according to the Trickflow website.
https://www.trickflow.com/parts/tfs-16918-16
They fit inside the stock seats, which if i remember correctly, are the valve seals themselves. Its a seat/seal deal. Right?
Can I buy just these springs and slap them into my LS3 head?
Old Jan 4, 2017 | 09:19 PM
07NBSChevy's Avatar
PAC 1218 Beehives are drop in replacements. They are 130 lbs at 1.800" and 318 lbs at 1.200" and have a max lift of .600".
Comp 918s are drop in as well. They are 125 lbs at 1.800" and 367 at 1.150" and have a max lift of .625".
Trickflow Springs are made by PAC Racing and the springs you listed from Trickflow are the PAC 1218's. A good price for the PAC 1218's is $139 which is what I paid for mine. Very good springs for a smaller cam under .580" lift for good spring life.
Stock seals have a built in seat. I recommend changing the intake and exhaust seals with new OEM seals while your in their since they are cheap.
Old Jan 5, 2017 | 05:16 AM
So just to be perfectly clear... any of the springs listed are compatible with the stock retainers and locks and will also sit on top of the stock valve seat/seal?
Old Jan 5, 2017 | 05:41 AM
Rectagular port ls3 head.
