Help with picking cams ?
Old Feb 13, 2017 | 11:53 PM
greend216's Avatar
Default Help with picking cams ?
I just picked up a set of 243 heads for my 2000 camaro z28 not going to get them ported but have long tubes and cat back exhaust what will be a good street stop cam that's aggressive ?
Old Feb 14, 2017 | 11:47 AM
KW Baraka's Avatar
Originally Posted by KW Baraka
Cam Motion, Brian Tooley Racing, Patrick Guerra, Tick Performance.
All can spec you a cam.........
All four of the above entities in the first line can be found via a Google search, or a search on this forum.
Best of luck!
KW
I'm just sayin'.
KW
Old Feb 15, 2017 | 08:15 PM
Nick.H's Avatar
I recommend Smallwood racing for custom cams. kip at cam motion is great too. Depends really on your goals for the car. If you want to stay pretty street able I'd say the tick SNS stage 2 is a good off the shelf choice
Old Feb 16, 2017 | 10:53 AM
pantera_efi's Avatar
Default EAP Camshaft Selection
Hi Green, I too am in So. Calif.
I can help you select a camshaft, one I have in stock, by using EAP.
This is a free "model" of your engine with stated HP/Torque.
You then chose after the report is viewed.
Would you like my help ?
Lance
Old Feb 16, 2017 | 12:04 PM
greend216's Avatar
Yes please
Old Feb 16, 2017 | 12:15 PM
OneQuickCoupe's Avatar
Lance
Nice Lance
Old Feb 17, 2017 | 10:54 AM
Default Engine/use information
Hi Green, I need more information for the model inputs.
One such is exhaust primary length and inside diameter?
The engine size, to be sure?
The port flow numbers ?
The C.R. ?
Your intended use/max RPM ?
Lance
Old Feb 17, 2017 | 12:20 PM
tims05allsap's Avatar
BRT stage 3 or four.
Old Feb 17, 2017 | 01:30 PM
Nick.H's Avatar
"BRT"? I think you meant BTR
