112 vs 114 LSA on low-lift truck cam
I'm likely going with TSP 212/218 low-lift cam for my 2006 LH6 5.3 Trailblazer re-build. They offer 112 and 114 LSA as standard. This will be a daily-driver, kid-shuttle. I understand that 112 will have the power (torque) more available down low but rougher idle so I'm planning to go 114. Any advice before I order?
Thanks!
Thanks!
I had the lunati version which is 212/218 113+4 and the idle was fine. I don't think you will have any problem with the 112 but if i was you i would go to www.performancetrucks.net and do a search since there are plenty of trucks over there with either cam.
sound clips
A few clips I searched up. It's hard to compare due to differences in tune, exhaust, idle rpm, etc.
212/218 112LSA
Another 212/218 but doesn't mention LSA. I'm guessing 112
212/218 114LSA
212/218 114LSA
212/218 112LSA
212/218 114LSA
212/218 114LSA
this is first start up after 215/215 112 install, no tune, stock exhaust with magnaflow muffler
http://vid291.photobucket.com/albums...ds/Camidle.mp4
