Why do people hate on stock ls3 castings
#161
#162
The right out of the box valve job on them looks pretty poor. And they need a little attention. I want the set Speed Tiger has the ls3 darts w/Low lash cam. His car is incredible with a stroked ls2 (ls3 heads). I cant believe he runs 3:70 gears. Doing 5's In the 1/8 down here.
#165
#166
Idk....that seems aweful strong dislike for a cnc head you can get for $6xx complete. Are there probably better ones? Most likely but for the $ they're hard to beat. A friend has a dirt car and uses them. His dirt ls motor made 740 crank hp with a hydraulic cam. Pretty good imo.
#168
#170
I'd kinda bet that cathedrals would always produce better 1/8th mile numbers cuz of the lengthy roll through first gear. But anytime you have shift recovery that holds the air pump beyond 5500 rpms the bigger square ports will shine
#171
Well well well... Brian Tooley said it in another thread. Its basically budget vs speed.
He went on to say I recommend LS3 heads all the time. They the best bang for the buck. No arguments. He even recommend them over the tfs/fast cathedral setup due to cost.
However if the customer wants the best performance and POWER he puts them on a set of TFS/Fast setup. The LS3 heads just dont seem to get the cars down the track as fast.
Then he went on to say if you think LS3 heads maje the power of TFS cathedral heads... you dobt know cylinder heads.
#172
#173
BTW once we start spending $ it's all a matter of OP. I can say this the Cat* heads do make me think and MAST are $1800 and they look Darn good (the *Cathedral* style heads are Proven street & track ready). I've gotten pass the *Cathedral, *Ls3, & *Ls7 wars as I would like to do another set sometime in the near future yet it comes back to budget so what then? And I do know and Ask alot of ?'s as I don't mind spending $ on heads as I would like another set.. *Best* bang for the buck are Ls3 Factory heads yet once we say aftermarket or spending coin$$$$.oo you do have Choices. A ls7 head is Superior to BOTH and are around the same amount of money when we say we are spending 2k + for heads and there made for all sizes.
So TRUE of a Quote.
Its basically budget vs speed...
#174
Why are people in this thread STILL comparing them as cathedral vs rectangle?!?!?
*****BANGS HEAD AGAINST KEYBOARD VIOLENTLY*****
*****THROWS KEYBOARD AND COMPUTER OUT THE WINDOW*****
Now I need a bandaid and a new computer....lol
#177
#179
Again it's not the SHAPE!!!! It's the AREA!!!!!
#180
My customer Nick McGrath holds the Extreme Street 1/8th mile MPH record with a 265cc "square port" head with a 2.200" intake valve (which some people would say is too big for that combination) at 153mph with a 76mm turbo and 3125 race weight. Will most likely set the Real Street MPH record at BG coming up, and if they can get the chassis bugs figured out hopefully the ET record. They only have 7 full hits on the car, and out of those 7 passes it has spun on 6 of them. The only full pass it made it went 5.01@153 with a 1.35 60' and not bringing in full boost until 2.8 seconds into the run.
Also don't forget about Mark Koehler, Ohio
Firebird, 7.50@194 MPH
106mm turbo/KUP/ERL hydraulic 441/TFS 245 heads/Edelbrock intake/315 drag radials. According to my calculation thats 4s in the 1/8 mile.
