It had to happen.
I been telling guys that for the longest. No one took my word....
Should we merge threads now? Or do we need a new one - stock ls3 castings are bad and so are aftermarket.
Btw, who designed these? Is Tony doing some sub work to AFR or did some apprentice of his take over?
the TFS LS7 heads came out after purchasing my MAMOFIED
LS3s but in hind sight my mid length runner FAST Intake
was better for me and my RPM range/combo then either the
FAST or MSD would have been with LS7 Heads.
Bigger ports also hurts the throttle response.
It would have been good to see how the medium bore LS3 port stacked up against the LS7 port at that high lift.
LS3/LS7 heads are great for the money but to Really the MOST out the heads you need to rev the motor like crazy which is rough on the valvetrain etc...
Its no big secret.. look and pay attention. Youll see alot of Ls3 headed strokers running 11s in F bodies. Why have a 11 sec 408ci?
its a waste of money.Then look at the guys running 10s naturally aspirated with strokers with a good pair of aftermarket cathedrals youll simply see which one hauls ***!!
I been studying LS stroker motors for years. Here on tech, Richard Holdnerer builds, GM high tech builds, engine masters, engine labs etc.....
