Building a 408
so here is a few questions
Carb or fuel injection?
What stroker kit did u buy?
What fuel are u running?
What kind of power are u making?
You have a number of stroker kits available... I used Eagle
I have 2 setups ones for pump gas the other for racing fuel
Thinking well over 700 with either.
I will say this it all depends on what your wanting. The cost can break you, still have to buy parts for the race gas set-up. I'm over 25k and still counting, trans included yet I did buy the best parts available, and if Sam Tech along with a few guy's from here and YB used it I bought it. Not mad at all. You can build one pretty cheap if you stay with the Carb setup. *Budget* is the key. On HP levels you can get anywhere from 500 to 800+ @ the flywheel on a N/a iron block 402 thru 416. Compression and RPM and depending on what type of intake you may want to use. Budget is your main thing to be concerned with along with getting the best Bang for your $. All the little stuff adds up quick.
Cam will be in the 270's range for duration and .730+ for lift to get to 800 fwhp.
Chris Frank does a nice job on them and has too many Ls3 combos doing very well Flyin is one. Made 709 fwhp with E85 and a Smallwood tiny Hydraulic roller cam 240ish with no vacuum pump. Ran 9.60's in a car under 3ooo lbs. He'll get 9.20-.40's once he gets some things sorted out. Kinda what I'm shooting for but with more Hp with either combo and around the same weight thinking around 2700 to 2800 lbs & bigger tire 305-315's. 8's? IDK but my end goal.
