Morel 6504 preload
Old May 7, 2017 | 11:46 PM
badazz81z28's Avatar
Default Morel 6504 preload
Seems nobody knows on the CF, anyone know Morels spec for preload on the drop in 6504 LS lifters?
I found a generic instruction sheet, but not part number specific
Old May 8, 2017 | 09:46 AM
1973 STEP A SIDE's Avatar
.045 to .060. Probably off the same sheet.
Old May 8, 2017 | 10:15 AM
JakeFusion's Avatar
Super Hulk Smash
.045-.050 if they are similar to the 5315s with Aluminum block and heads.
.030-.035 iron block and aluminum heads.
From what I've seen.
Old May 8, 2017 | 11:51 PM
Looks as though it won't be easy. With my push rod checker I get about a little over 17-1/2 turns to a little less then 18 turns from valve to valve. If I go with a 7.750 pushrod I'll have as much as .065-.070" preload as if I go with the 7.725 I'll have as low as .035-.040"
Theres no middle ground without going custom. Is it better to have more then less pre-load?
Old May 9, 2017 | 07:20 AM
What head are you running ?
Old May 9, 2017 | 07:49 AM
Stock LS7 heads that were rebuilt and ported by Texas Speed. I think they milled .035" and there is a stage 2 cam in it. Not sure if that cam has a smaller base circle then stock
Old May 10, 2017 | 09:55 PM
thoughts?
Old May 11, 2017 | 03:01 PM
Cstraub's Avatar
The lifters has between .139 and .141" of travel. On an LS engine depending block and head material you want between .040 to .060" of pre-load. An all aluminum engine will be at the .060" side of things.
