6.0 with LS3 heads/cam/intake
Old Sep 8, 2016 | 09:17 AM
JimmyGTO's Avatar
Default 6.0 with LS3 heads/cam/intake
My car is a 06 GTO m6 with 24,940 miles. It has a monster 2 clutch, 1 3/4" Kooks with hi-flow cats, h-pipe, 4" magnapacks. It was on a dyno May 2015 results were 374/377. Here is what's going to be installed on the car in about two weeks
new LS3 heads worked on by Advanced Inductions
.040" cometic head gaskets
new GM Rocker arms
Cam Motion Cam
Morel 5315 lifters
5/16" pushrods 7.350"
ARP head bolts
new LS3 intake with injectors and fuel rails modified by Rick Crawford
GM oil pump
Improved Racing bracket and bolt
GM LS2 timing chain and gear
Straubs bronze bushing trunnion kit
4" spectre tube with couplings with 100 maf
misc. parts, gaskets and bolts
New KOOKS 1 7/8" headers - UPDATE
6.0 with LS3 heads/cam/intake-cam.jpg
6.0 with LS3 heads/cam/intake-heads.jpg
6.0 with LS3 heads/cam/intake-intake.jpg
Old Sep 8, 2016 | 09:19 AM
HCI2000SS's Avatar
Sounds good!
Old Sep 8, 2016 | 09:32 AM
JimmyGTO's Avatar
Originally Posted by HCI2000SS
Sounds good!
Thanks, hoping for about 450hp.
Old Sep 8, 2016 | 09:42 AM
HCI2000SS's Avatar
I'm sure it will be every bit of that
Old Sep 8, 2016 | 02:59 PM
JimmyGTO's Avatar
Won't be long I will find out.
Old Oct 1, 2016 | 07:19 AM
JimmyGTO's Avatar
UPDATE - Started the tear down of the top end. I will be loosening the oil pan today and removal of timing set, lifters, trays and cam. Then clean everything up to do the flycutting of the pistons.
Old Oct 1, 2016 | 07:31 AM
KCS's Avatar
KCS
Moderator
How big is the cam?
Old Oct 1, 2016 | 07:36 AM
ragtopz28's Avatar
Although your dog doesn't look too impressed, lol...I'd like to know the cam specs. I just did a LS3 topend 6.0 (231/247 .619/.624 113). In for results.
Old Oct 1, 2016 | 07:59 AM
JimmyGTO's Avatar
The cam is a Cam Motion cam spec'd by Pat G. it's a 230/238 .626 113+3.
Old Oct 1, 2016 | 05:16 PM
Jimbo1367's Avatar
If Pat G spec'd it, it'll scream !!! What was your criteria/needs for spec'ing the cam?
What CC program did you go with on the heads? Any milling?
Old Oct 1, 2016 | 05:38 PM
JimmyGTO's Avatar
I'm hoping it will scream. Advanced Induction milled the heads to 64.8cc and did the 280cc program. Phil @ AI is a great guy to work with.
Old Oct 1, 2016 | 06:41 PM
Jimbo1367's Avatar
hat CR should that get you to?
Old Oct 1, 2016 | 06:54 PM
JimmyGTO's Avatar
11.2 comp.
Old Mar 22, 2017 | 08:03 AM
JimmyGTO's Avatar
UPDATE It's been a long winter and a few minor set backs on the car. I didn't feel a rush to get them fixed quickly, so I took them one at a time. No real big problems just a little pain in the butt. Went from Kooks 1 3/4" headers to 1 7/8". Fixed the steering knuckle line leak. Order some speedhut gauges, finally got them installed. Installed the 4" tube with the LS3/7 maf along with the wiring harness adapter. The car would start easily but would die in about three seconds. Reinstalled the stock maf so I will able the load and unload the car on the trailer when taking it for the dyno tune. Dyno tune is schedule for April 7th at noon @ RPM Inc in Garner, NC. Chris at RPM said we can install the LS3 maf after getting down there. Will post the outcome.
Old Mar 22, 2017 | 11:06 AM
dw456post's Avatar
Hurry up!! It's Spring already
Old Mar 22, 2017 | 12:06 PM
JimmyGTO's Avatar
I agree!!!!
Old Apr 7, 2017 | 09:21 PM
JimmyGTO's Avatar
UPGRADE Dyno tune was today. Final numbers are 480.96/434.37 with a SAE CF. All the parts I used came together nicely. Want to thank Phil at Advanced Inductions, Pat G for the cam and for specs I needed to shoot for. Andy Vasbinder for help with flycutting the pistons. Plus the parts I bought through Brian Tooley Racing. The build really came together.
Old Apr 7, 2017 | 09:46 PM
Dyno Junkie's Avatar
Would you mind posting the dyno graph.
Similar cam to what is in our LS3, 231* 239* .617" .624" 113*
Heads are milled .075" and pistons flycut .100".
1 7/8" extractors and Rick Crawford manifold.
Attached Thumbnails 6.0 with LS3 heads/cam/intake-image.jpg
Old Apr 7, 2017 | 10:15 PM
JimmyGTO's Avatar
I will post it tomorrow plus a video
Old Apr 8, 2017 | 09:06 AM
JimmyGTO's Avatar
[QUOTE=Dyno Junkie;19586421]Would you mind posting the dyno graph.
1 7/8" extractors and Rick Crawford manifold.[/QUOTE
Which head gaskets are you using? You must be running high compression. What is your timing?
6.0 with LS3 heads/cam/intake-dyno.jpg
will post video later. I need my son to help me with that. lol.
