Ls3 front cover oil leak
Old May 8, 2017 | 10:28 PM
hot98z28's Avatar
Default Ls3 front cover oil leak
I did an ls3 swap into my 98 camaro, Mahle pistons melling high pressure oil pump, ls9 cam and headers. Block was machined and bored .10 over. So everything is new other than crank and rods which machinist said were in great condition. Well I have a leak coming from the crank seal and it only leaks when I get on it. Will the high pressure pump have something to do with it? Or is it just the seal, I did not use the balancer to align seal. Thanks
Old May 9, 2017 | 07:47 AM
hot98z28's Avatar
What I'm trying to ask is do I keep the high pressure spring or change it out to stock pressure since I'll be replacing seal, I can knock both of them out at same time.
Old May 9, 2017 | 11:13 AM
cookseyb's Avatar
Check your PCV system, crankcase pressure will blow by the seals. if it is not working correctly. You might need a Cannister....
Old May 20, 2017 | 01:34 PM
hot98z28's Avatar
Turns out it was a bad seal that came with the front cover from summit, It was really hard like seals that are about to break. Put new one in and problem solved.
Old May 20, 2017 | 02:51 PM
Must have been on the shelf a LOOOOONG time!
Old May 20, 2017 | 05:31 PM
hot98z28's Avatar
Lol Yea I bet. I buy from summit a lot and this is the first time I've said something bad about their product, but hey the replacement gasket was like $8 so I ain't mad. I was mad when after a pull my undercarriage was covered in oil tho lol.
Old May 20, 2017 | 09:12 PM
Hey just consider your undercarriage RUSTPROOFED! Yeah, that's the ticket......
Old May 21, 2017 | 05:33 AM
stevieturbo's Avatar
The OEM seals are a strange thing and are quite hard.
All it can take is the tiniest speck of dirt to get trapped under the lip and it can leak loads, but it wont be the oil pump itself causing the problem.
