109k LS2 for Swap - Request recommended service
Old Jul 14, 2017 | 09:31 PM
Lhurgoyf's Avatar
Default 109k LS2 for Swap - Request recommended service
Hello All,
Recently picked up a total'd GTO for an engine swap, and has a decent sounding LS2 in it. I'm going to pull it apart, and want to know if there is there anything i should check and plan on replacing with it being a 109k mile engine? I'm likely to put a new cam/lifters in it, likely timing chain, but not sure if i should watch out for anything else.
(May have a small cam in it due to the idle.. or just needs a tuneup. And that is not a cold rev, there's an edit to pull ~3-4 minutes of boring idle)
https://drive.google.com/open?id=0B-...UVGZlJUQ0EzSHM
Old Jul 14, 2017 | 10:09 PM
I would say freshen up the top end; if cam/lifters are the plan, then you will need valve springs and possibly pushrods of the correct length (check for that; there are threads here on doing it). A new timing chain and oil pump, along with a complete upper-end gasket set with front and rear cover gaskets. Best bet is to call WS6 store (a sponsor/vendor of this site) and tell them your situation. You will be dealt with fairly and accurately, with good pricing and service. Have fun with this!
Old Jul 14, 2017 | 10:27 PM
Spamfritter's Avatar
The 2005 and 2006 GTO's often had water pump and t-stat housing issues. Other than that, they are solid engine wise.
Old Jul 14, 2017 | 10:50 PM
^^^^^^Good points!^^^^^^
Old Jul 15, 2017 | 08:25 AM
A.R. Shale Targa's Avatar
Should do cam/lifters(TICK stg.1 V2) and springs/push rods. Freshen the heads, VJ, surface and just leave the stock short block alone. Would be quite the strong runner with great drivability.
If you know it ran with good oil pressure then I would not even break the rod caps or mains just to peak cuz I've seen the big ends of rods distort after re torquing and that could take out a bearing pretty quick
Old Jul 15, 2017 | 08:30 AM
kinglt-1's Avatar
Put a new oil pump on it...cheap insurance.
Old Jul 15, 2017 | 01:30 PM
Lhurgoyf's Avatar
Thanks everyone!
high-level Parts-list so far:
Maybe start off with package in: http://www.tickperformance.com/tick-...r-ls2-engines/
Oil Pup
Cam
Lifters
Pushrods
Valve Springs
Fresh Gaskets all around.
Surface the heads
Maybe replace water pump while it's out.
Think the Ticket Street Heat stage 1 packaged with headers/intake/tune is worth 400rwhp? Or should i just go big with the Stage 2, or the Polluter if i want to get nasty later with heads/intake.
Old Jul 15, 2017 | 04:44 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Gtos had major issues with spinning rod bearings esp on cyls 7 and 8. Usually their pan design is to blame. Some like to lift ring lands back there also.
We have a complete package that will net well over 400rwhp on a gto so youd make more in any swap also that is less $$ invested also. It doesnt have a flashy name though.
We can get you set up with every single piece you need along with tech support and any questions you have.
I would check the rear rods and bearings back there first. Do not use that pan if you can help it either. Upgrading to a quality oil pump and uncapping the backs of the heads will allow for better coolant flow and heat exchange and not cause other issues normally associated with the gtos. TBSS had the same issues mostly related to the same root causes, but also because of some crap parameters in the gm tuning.
Old Jul 23, 2017 | 08:53 AM
cookseyb's Avatar
You will need a new pan, the front sump don't fit much and had oiling issues..
Old Sep 27, 2017 | 09:32 AM
Hibs's Avatar
What exactly is this process ?
Old Sep 27, 2017 | 10:12 AM
Basically the "steam holes" should be plumbed so coolant/steam can bleed up and out of the system to ensure all air escapes. There is a steam hole at each end of the head, some of which might have a plug in them.
Old Sep 27, 2017 | 11:21 AM
Hibs's Avatar
So remove plug, then route plumbing where?
Old Sep 27, 2017 | 12:01 PM
Like this from Earls
Connects back to where it normally would on radiator etc
Old Sep 27, 2017 | 12:49 PM
Hibs's Avatar
Cool thanks. I'm working on an '07 TBSS, in the process of head and camp swap. I'll check out those plugs before I plop on the new heads. Thanks!
