Looking for advise.
Old Jul 26, 2017 | 08:30 AM
ramirop's Avatar
Default Looking for advise.
im currently looking for a small cam for my daily driver. I have my eyes on tsp 220r 220/220 .600/.600 lsa114 or the 224r. I'm planning on upgrading to the 243 heads work shorty headers, as far as the valve train what will I need. Can I use my stock lifters if not which ones should I get. Of course since I'm going with 243 I'm assuming I need newer push rods. On the rocker arms should I go with gm performance 1.5 and the beehive springs and use the same valves.
Old Jul 26, 2017 | 11:39 AM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
With shorty headers I would do 220/226, 222/228 , 6*, split mild lobes
Under .580" lift. Cam Motion has what you need and can advise as well.
Talk with Steve AKA Speedtigger on this forum.
Good Luck.
Old Jul 26, 2017 | 12:14 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Use your stock rockers.
We have a great cam for your application.
Our high lift hot cam. Cam and springs runs $515. The springs are beehive so they work on your 243 heads with no issues!
Here it is
Old Jul 26, 2017 | 01:33 PM
CAMSTER's Avatar
I like the hot cam above but the shorty headers are garbage I will use ls7 exhaust manifolds instead and are dirt cheap and should bolt rite up.
Old Jul 27, 2017 | 10:28 AM
ramirop's Avatar
Do you have audio on this particular setup.
ramirop's Avatar
Here it is
Old Jul 27, 2017 | 10:43 AM
ramirop's Avatar
If I go with the ls7 manifolds, will my stock exhaust bolt up or will I need some custom work?
Old Jul 27, 2017 | 10:51 AM
LS7 manifolds exit center-down. Which car are you putting these on? If it's a Camaro they likely will not fit too well. And they will not bolt up to stock exhaust.
Old Jul 27, 2017 | 11:05 AM
ramirop's Avatar
It's an f-body and I just saw pics of the manifolds, they are not going to work like you they exit from the center. I'll stick with shorty, I lowered my car so I don't want long tubes.
Old Jul 27, 2017 | 11:07 AM
I included the link so you could click on it. it has the audio clip, dyno sheet, full description in there.
