AFR LS3 Head Thoughts...
"Fixed heads" only reset the clock of the failure and problems associated with ported OEM castings and stock rockers....the problems and issues are going to resurface again.....you have to change some of the players (valvetrain components) if you expect to have different end results.
It's just one of the reasons I always advocate getting away from stock rockers. I don't know why so many people are intent on running them. They were designed to operate with half the spring pressure (seat and open pressure) most of us run, SOFT gentle OEM cam lobes/ramps, and .100 or more less lift. That's the application they were designed for....they are out of their element on most of the aftermarket builds and will take out the guides of your heads due to all the side loading imparted on the stem of the valve and the guide as the flat arced pad of the rocker scrubs and see-saws across the tip of your valve. You end up with an hour glassed shape valve guide and oil consumption issues once you have achieved that shape which is vastly accelerated with aftermarket cams and alot more spring pressure....not to mention a loss of performance from your valves not properly sealing when your guides are worn.
ALL the engines I build and spec are equipped with Yella Terra Ultralites built specifically for the castings Im using but you can buy them for stock heads also....much more affordable than the other big names in the rocker arm business and more importantly they are better designed for an HR system most of us are running (they are lightweight which is crucial to valve control).
I don't understand the love affair with OEM rockers when your upgrading all the other areas pertinent to building a real performance engine, not to mention some guys investing more money in them with trunion upgrades etc.....its silly because you still haven't addressed their major design flaw regarding not having the proper geometry for much more lift and not having a roller wheel which reduces contact patch by a large margin and reduces side loading dramatically as well. Also a roller will offer reduced friction and that will free up a small bit of power also....a nice perk from the upgrade to a roller.
I stock this stuff guys so if you would like to discuss in more detail feel free to contact me. Not a single engine I build (or help spec for a customer by providing them with all the parts) includes OEM rockers. You leave them to collect dust on the shelf with all the other OEM parts you removed when you decided to upgrade and mod your engine in search of more power. The engine is a tuned system.....when you upgrade the valvetrain in other areas (springs, camshaft lift and profile, etc.) you have to also upgrade the rockers as well to better compliment the other changes....this gives you a more reliable piece and a harder running one as well
We should get on the phone at some point to discuss the project in more detail. When you're ready to really dig into this PM or email me and let's do that. Plan ahead though.....with AFR's lead time and my lead time it's easily a 7-8 week wait to get them.
Regards,
Tony
Option for the needle bearing paranoid as well (I resemble that remark!).
LOL
64 Post is using the Crower RR in his 416" AFR LS3, W/ LLSR,
& Hi Ram, E85 Build underway.
Edit - in case anyone connects this with the clutch thread, I added the clutch six months later
The T&D's are great, as are the Crowers. I've ran both in the past in circle track stuff with success. The rpm we ran, along with springs required me to spend the coin on my rocker setups. BUT...most guys here never race their stuff...ever.
Tony Mamo puts his name on YT these days. I have just received a rocker set from him, and it says Mamo right beside the part number. It's what Tony speced for the top end package I've got from him. I've never ran YT's before, so I'm entering new territory here, hence why I feel this discussion should take place.
So besides YT's, what other rocker failures have taken place? Surely there's a way to run a roller tipped rocker, and not spend $2k doing it...
http://www.autopressreleases.com/_up...%20Engines.pdf
Reduces valve sweep by 400%? Really? So, instead of valve sweep of X, its -3X? I'm sure they mean it reduces it by 75% or the regular GM rockers have 400% more sweep.
and three times less MOI over the valve tip? You mean 1/3 the mass?
I've never seen them reviewed, and they might actually be a great product, but at that price point, you're in YT ultralite territory.
1/3 the moment of inertia and 1/3 the mass is not the same. Mass moment of inertia is a property that is influenced by total mass, location of the center of mass, and as such the geometry of the part.
The moment of intertia is what actually matters in the dynamics and control of the assembly.
These won SEMA's best new product at SEMA 2016. I'm also curious why they haven't really shown any builds yet.
In all truth it looks like a great concept. But I wonder if the price point is too close to yellaterra so people just get the YT?
The 'engineers' give the advertising agency the product information and the agency 'massages' the wording for maximum effect.
KW
