Calculating compression question
LSX 19260093 machined to bore of 4.125 and stroke of 3.662
4.125 -12cc piston
Callies Ultra Billet 6.125" I-Beam, ARP 2000 Bolts
Callies Dragonslayer, Wet Sump, 6-Bolt Flange
ARP Main Stud Kit
24x wheel
Trickflow 245cc heads Cathedral-Port 6-Bolt, 70cc
Cometic 6-Bolt .051"
ARP Head Stud Kit for 6-Bolt Heads
Yella Terra LS1 1.7:1 rockers Adjustable Set
Tool Steel Wrist Pin Upgrade
Heads are trick flow 245cc with combustion chamber of 70cc
https://www.totalengineairflow.com/p...ylinder-heads/
I'm trying to calculate compression (desired is 10:1) and to do that I see that Piston deck clearance is needed.
Block deck height is the distance from the center line of the main journals to the block deck surface. So assume this lsx block that comes in at 9.260 get's machined down to a 9.00-inch deck height. Using 6.125-inch connecting rods, and a stroke of 3.622 inches. I divide the stroke by two and add that to the rod length: 3.622 / 2 = 1.811, and 1.811 + 6.125 = 7.936. Next, subtract that answer from the deck height: 9.00 – 7.936 = 1.064.
So the piston compression height is 1.064 inches.
So does this mean that a piston compression height of 1.064 puts the piston exactly at the top of the engine block?
By this calculator, the deck height clearance is 0?
https://www.uempistons.com/index.php...9171c5d79e713e
I'm I correct in that the Head Gasket Bore Diameter for a bore of 4.125 is 4.125 unless otherwise stated on the gasket specs, and that you would enter that value into the calculator here because the calculator already has an entry for compressed head gasket thickness?
http://www.csgnetwork.com/compcalc.html
That would give a compression of 10:1 if -7cc dish pistons are used. Is this correct? Is there an off shelf -7cc piston for the 4.125 bore and 3.622 stroke using 6.125 rods or do you have to go custom?
Other option is to change the heads. A set of 285cc with 66cc combustion chamber and wisco -12cc pistons with a Cometic 0.045 gasket. That would be 10:1 compression also.
I think JE sits .0015 in the hole all piston makers have these.
https://www.jepistons.com/Catalogs/A...m_ls_dish.aspx
Deck clearance is 0 based when you put those values into the calulator:
However I read that the ls1 stock has a deck clearance of 0.006
LS standard deck height is 9.240.
Bore x Bore x Stroke x .7854 x 16.4 is the volume of a cylinder in cc.
Easiest to think of swept volume, deck, and gasket as coins of different thicknesses stacked on each other.
Chamber plus a dish or Chamber minus a dome = Volume at tdc + net volume of deck and gasket.
- .008 Positive Deck= 1.75cc
+ .051 Gasket= 11cc
+ Chamber volume= 70cc
+ Dish Volume = 7cc
___________________
Nets 86.25 cc compressed volume
(swept volume=794cc)+(86.25) = 880 uncompressed volume
880 / 86.25 = 10.2
It's better to run the quench about .040 and get the volume in the chamber or piston.
3.622/2 + 6.125 rod = 7.936 9.240 - 7.936 = 1.304 piston compression distance for zero deck
Some piston manufacturers will let you make one change (volume in this case) (or it could be compression distance just as easy) to a shelf stocking piston part number for a nominal charge. It is actually a full custom piston and delivery takes several weeks, but it's an inexpensive way to hit the number exactly.
Easier and quicker is to have the heads milled and use the piston deal to set deck. The LSX block decks often come in a little higher than 9.240.
So for this piston here:
https://www.summitracing.com/parts/j...63-1/overview/
It gives a CD as 1.187in. It's a 4.125in bore, 3.625in stroke, rod length 6.0in
So when they designed this piston, it was made to be as close to 0 deck clearance as possible on setup with a 9" deck height??
When you plug in the deck height of 8.999 into this calculator, it yields 1.187in piston compression height:
https://www.uempistons.com/index.php...ge=calculators
The calculator gives 0.000499999999999 deck clearance when you use the info above, so essentially zero deck clearance.
So if someone wants a quelch of .040" in this setup, then they would THEORETICALLY run a head gasket that has a compressed thickness of 0.040", correct? Do they increase the bore diameter of the gasket also for a better seal? Like use 4.135" bore diameter gaskets with compressed thickness of 0.040" since the bore is 4.125" ?
So the correct way is to actually measure how much the piston is actually sticking out, and then base the thickness of the gasket on which piston sticks out the highest. So in the end, you may get close to your theoretically calculated compression, but getting the proper quelch is more important than hitting that theoretical target compression number perfectly. Got it.
The 6.098"-6.125" rods are great on the 3.622 stroke and a taller piston (1.34") Comp height is both light and stable in the bore which minimizes ring flutter. Better ring seal is more power
Is this the correct way to do it? Those athena head gaskets made in Sweden which are supposedly the best the way to go, but are only available in certain bore sizes. Given the cylinder bore size, the bore size of the LS7 285cc heads and the compressed thickness of those athena gaskets, or would you use those or just use a 0.051 compressed thickness cometic gasket that has a bore of 4.160? If spending the money on a 6 bolt setup, I want the correct gasket size given the bore size of the heads being bigger than the bore size of the cylinders. If the quench needs to be brought to 0.040, how would you do it?
Cylinder Bore Size 4.130
Piston Stroke length 3.622
Head Gasket Bore Diameter 4.170
Compressed Head Gasket Thicknes 0.059
Combustion Chamber Volume in CCs 70.000
Piston Dome Volume IN CCs -5.114
Deck height 9.240
rod length 6.125
Amount milled off the head 0.000
Piston compression distance 1.304
Piston Deck Clearance 0.000
Modified Combution Chamber Volume in CCs (still 70.000)
Swept volume cc 795.134
Gasket cc 13.204
Deck Clearance Volume cc 0.000
Total Chamber volume cc 88.418
Compression ratio 10:1
Quench 0.059
Assuming this is a boosted application, the quench isn't really that important like it would be in a naturally aspirated engine. No need to stress over it as much as you are. So for the goals you've stated, you could use a 4.130" bore piston with a 1.304" compression height and a 5cc dish (JE PN 311970) with a 6.10" rod to put the piston in the hole at TDC. Your machinist could then mill about .015" off the heads to go from 70cc to 67.5cc, and then flat mill the block about .005" so that the pistons will end up about .020" in the hole, which will put you right around 10.0:1 depending on the gasket you use.
So if we keep piston diameter at top ring land as 1.304 and distance from top of piston to ring land as "0", I get 9.76 using this calculator, which matches what I have in the calculator I made in M$ excel.
http://crt-performance.com/compression.htm
I'd like to be able to incorporate both piston diameter at top ring land and distance of top of Piston to Ring Land into my calculator which I've attached.
So if the compressed thickness of the gasket is 0.059 and the pistons are 0.020 in the hole, what would the quench be? 0.059 + 0.020 = 0.079 in?
And a quench of 0.079" is not a problem on a boosted car?
However, without actually measuring the piston, the OD at the top ring land is a guess at best. You're assuming a lot right now. If you're trying to get that precise, which personally IMO is a waste of time, you should also consider whether or not the top ringland has the "anti-detonation" grooves machined into it and how much volume they add.
Keep in mind that most builders don't bother with all that guessing in their compression ratio calculations, so if you've decided you want 10:1 based on what others have built, chances are that you're using a different calculation and it's not comparable to what you've researched.
Yeah, it won't be a problem. I'm not a tuner, but many of the guys that do tune the big power adder cars seem to prefer it as it has shown to help widen the margin of error in the tune up.
Now the other option is to use a gasket which has more flexibility in the bore and compression thickness and then you don't have to mil to 0.030, but I hear the Athena gaskets which are supposed to be the best for LS7 heads on boost.
I realize this is a "just give it to the builder and they will figure it out" kind of thing, but i'm just trying to understand how exactly it's figured out.
