Prc 260cc Ls3 heads
The PRC 260 heads don't have the valves in the stock location. Because of this, they have the rocker stands machined into the head. You can use stock rockers without the factory rocker stands. Any direct replacement roller rocker will also work, if the intake and exhaust rockers are not connected with a shaft. I have a set of these that I plan to modify so I can run Harland Sharp adjustable rockers and an LLSR cam from Cammotion.
